PocketWizard MiniTT1 Transmitter and FlexTT5 Transceiver Radios for Nikon Cameras
2011 CES News Nikon Studio & Lighting
PocketWizard Introduces MiniTT1™ and FlexTT5™ Radios for Nikon Cameras
Highly anticipated controller system available in January
So. Burlington, VT – January 5, 2011 – PocketWizard, the industry leader in wireless control and synchronization of cameras, flash and light meters, announces its MiniTT1 Transmitter and FlexTT5 Transceiver for the Nikon DSLR camera system. Sales of the Nikon versions in the U.S. are expected to begin January 2011. Canon-compatible versions are available now.
Following months of intense development, PocketWizard is in the final testing stages of the highly-anticipated ControlTL™ system for Nikon products. Nikon DSLR photographers will soon enjoy the ease of TTL exposure automation with the simplicity PocketWizard’s ControlTL™ system, featuring the MiniTT1 Transmitter and FlexTT5 Transceiver. These new i-TTL capable radio slaves make taking off-camera flash as effortless as slide-in, turn-on and shoot.
Combining TTL automation with the reliability of PocketWizard radio technology results in perfect off-camera flash photography in any environment – around corners, out-of-sight and even outdoors in bright sunlight. The MiniTT1 Transmitter and FlexTT5 Transceiver can be used to control single or multiple off-camera Nikon i-TTL flash units at speeds up to 6/fps and faster. Thanks to upgradeable firmware, these units will remain current even as camera technology changes.
“Perfect for commercial, wedding, sports, fashion photography and so much more, PocketWizard’s wireless triggering systems make some of the most difficult lighting situations not only possible but amazingly easy,” said Dave Schmidt, Director of Marketing, PocketWizard. “Nikon makes a really great flash system. When photographers add the MiniTT1 and FlexTT5 to their existing arsenal of equipment, the photographic possibilities are endless.”
The Nikon-system PocketWizard MiniTT1 Transmitter is a tiny, low-profile unit (2.8 x 1.9 x 1.3 inches) that slides into the camera’s hot shoe. The FlexTT5 Transceiver is also low-profile but slightly larger (3.6 x 2.9 x 1.4 in.) transceiver. Both take the complex TTL exposure data being sent through the camera’s hot shoe and digitally transmit it as a reliable radio signal.
These new PocketWizard radios can be used to trigger an endless combination of TTL or manual flash units placed wherever desired to illuminate a scene. Nikon flash units slide into the shoe of a dedicated FlexTT5 Transceiver for TTL operation; there are no wires or connecting cables required. Any change in ISO, aperture and shutter speed is automatically adjusted for. The full range of Nikon flash control is efficiently passed along giving the photographer convenient on-camera control of their remote dedicated flashes. The units are also compatible with any PocketWizard radio permitting simultaneous triggering of manual flash, remote cameras or mixing TTL flash with manual flash if desired.
For typical TTL operation, the MiniTT1 and FlexTT5 require no buttons to be pressed or settings to change other than the camera’s shutter speed – to provide FP (High Speed) flash sync all the way to an unprecedented 1/8000th second. This allows using flash with wide-open apertures (for shallow depth-of-field), and outdoors in bright, outdoor sunlight resulting in some amazing new images. ControlTL technology also enables some previously impossible camera capabilities including HyperSync™ for flash synchronization above the camera’s x-sync with full-power manual and studio-type flash units.
Both new PocketWizard units have a two-position channel switch that can be programmed via a computer (using the supplied USB cable) or set in the field with a built-in “Learn” mode via another PocketWizard radio. The system features 20 ControlTL channels as well as all of PocketWizard’s 32 discreet channels for traditional triggering. By plugging a Mini or Flex unit into a computer with the PocketWizard utility software loaded, photographers can configure channel, HyperSync timing, sleep timers and more or they can simply update the unit’s firmware with push-button ease.
The new PocketWizard MiniTT1 and FlexTT5 radios offer more capability than any radio triggering units marketed. As digital technology advances, more capabilities will be added to the system, essentially offering “future proof” technology that adds even more value to this remarkable system.
Accessories available soon for these new PocketWizard units include the Nikon-compatible PocketWizard AC3 ZoneController, which allows the user to control three zones (A,B,C) of Nikon flashes or groups of flash units mounted on Flex TT5 transceivers in either automatic-exposure or manual control. Also available is the PowerST4 radio receiver that plugs into an Elinchrom RX flash units and controls power level, modeling light functions when used with a Mini or Flex or can be used as a standard receiver for regular PocketWizard units. Similarly, the new AC9 AlienBees Adapter slides into the shoe of the Flex TT5 to interface with AlienBees flash units. Both work with the AC3 for even more control and versatility.
About PocketWizard
Incorporating the latest radio technology, PocketWizard exceeds the demands of the working pro with durability, ease of use, advanced capabilities and legendary PocketWizard reliability.
PocketWizard products, including the PlusII, MultiMax, MiniTT1 and FlexTT5 are made by LPA Design, based in South Burlington, Vermont and sold by distributors around the world including the MAC Group in the USA.
All PocketWizard User Reviews
All Flash Accessories User Reviews
Studio and Lighting News, Reviews & Articles
2011 CES News & Articles
PocketWizard Web Site
  • Photo-John says:
    It’s about time! Hasn’t it been about two years since these came out for Canon digital SLRs?
  • Ian Hylands says:
    I’ve been using the Pocket Wizard MiniTT1 and FlexTT5 for several months now as a beta tester, and I have to say that I haven’t had any real issues with them. I’ve heard stories from other photographers of inconsistencies, but I’m going to assume those relate to early test models and firmware. In the time that I’ve shot with them I’ve had no problems, and made a few discoveries that make them even more useful for the work that I do.
    I’ve used them in iTTL mode (mostly to manually adjust flashes remotely, I hate TTL) with no issues. I do need to say that I have very little experience using them with actual TTL flash, it’s just not something I do. I’m sure it works well, I just find it easier to set everything manually the way I want it. One great benefit of using them in TTL mode is the modeling light feature is greatly improved. It’s just as easy to remotely trigger it with the DOF button, and it’s a lot brighter using the MiniTT1/FlexTT5 set.
    I spent a bunch of time playing around with them in AutoFP high speed sync mode, and it works great, no problem shooting with them at 1/1000th I haven’t played around with the feature to light action on a bright sunny day yet, but stay tuned, I’ll get to it sometime soon when it’s actually sunny out here in the NW.
    I also played around a bunch with the Hypersync offset feature, using both FlexTT5 receivers and MultiMAX receivers. It works well, my only criticism would be that I don’t think the offset goes quite far enough. But then I like to push things beyond what most people do…
    I definitely won’t be getting rid of my Pocket Wizard MultiMAX units, they still have a lot of features that I regularly use, however the MiniTT1 and FlexTT5′s have made a great addition to my Pocket Wizard toolbox. If you’ve been waiting several years as I have for the Nikon version of these things get out there and purchase a set, you won’t be disappointed.
    I created a short blog post about my latest shoot with the MiniTT1 and MultiMAX’s, you can see it at http://tinyurl.com/24htgfc
  • Photo-John says:
    Thanks for the comment, Ian. You definitely push flash harder than most photographers so it’s good to hear they’re working well for you. Thanks for including the link to your PocketWizard MiniTT1 and Multimax blog post, too!
  • al-manaai says:
    i used the pocketwzizerd with lens 70-200 -d3s nikon it dose not work event that i used it with 24-70 it is work i dont have any proplme . cane you advice me for this issue .
    best regards
  • al-manaai says:
    hi ,
    i used PocketWizard MiniTT1 and FlexTT5 yesterday in the shooting the flash was working but before the photo is taken , i think it speed was faster than the camera , so i want to ask this pocket should i use it with special kind of camera or there is some option do i have to choose becouse it was faster than the camera and the photo was very dark.
    by the way i used it with 70 – 200 mm nikon and it was faster and it doesnot wrork
    but when i used it with 24-70 mm nikon it was working perfectly and the 14-24 mm nikon it was also good so i want to ask is the problem in my camera the 70-200 and the 105mm micro nikon becouse it wasnt working or do i have to change somthing in the pocket ?
    the options i used in the70-200 and the 105mm micro nikon , was manaul and the shutter speed was 100 and the apture number 2.8 , the flshes were on TTL and it was not working ,,
    so is it something i chose ?
    the camera type was D3S nikon
